Old 05-04-2007, 11:49 AM   #11 (permalink)
Tmoney is on a distinguished road
Yester, what are you running on your Q?
Tmoney is offline
Old 05-09-2007, 01:29 PM   #12 (permalink)
Default ?
So I reset my phone again... I left it stock and had no problems.
I must be installing something incorrectly.
Where do you place files for install on the Q?
Tmoney is offline
Old 05-09-2007, 01:31 PM   #13 (permalink)
i usually DL or copy files to my SD card and run them from the Q's file manager
Old 05-09-2007, 02:37 PM   #14 (permalink)
Yester18's Avatar
Yester18 is on a distinguished road
Software?
Nothing....
Yester18 is offline
Old 05-09-2007, 07:59 PM   #15 (permalink)
Default Last question...
Ok so this should be the last question for you guys and thank you so much for your help!
Does anyone else running the same software I have on my phone have these same issues? I was just wondering if it could be facade or orange.dll.
I am going to try and exchange the phone tonight and I wanted to make sure it wasn't just the programs that I am running. It doesn't seem like anyone else with these programs or software on there phone are having these issues.
Again, thank you all very much!
Tmoney is offline
