Old 10-12-2007, 03:39 PM   #1 (permalink)
blazinazn's Avatar
blazinazn is on a distinguished road
Default Need help with profile!
I was in the registry editing the order of the list in:
HKCU\ControlPanel\Profiles
After doing so all of the entries under Settings\Profiles are gone. Even when I hold down the home key, the selections for the profiles are no longer listed.
Anyone have an idea how I cant get these profiles back?
I tried doing a a soft reset but still no luck. Anyone care to give me the default order and names for each of the entries in the registry so I can compare them to what i have now?
I also changed the name of one of the folders but I did changed it back in the registry when they disappeared from the list. Any help would be greatly appreciated.
blazinazn is offline
Old 10-12-2007, 03:42 PM   #2 (permalink)
in the Profile screen can you still press Menu > Reset to default ? not sure but it might work...
Old 10-12-2007, 03:49 PM   #3 (permalink)
blazinazn's Avatar
i can not reset. all it has 'selet' but it's greyed out and i can't click it.
Old 10-12-2007, 03:53 PM   #4 (permalink)
was worth the try... well, short of a Master Reset.. when i edit my profile slightly it writes a .xml on the phone, perhaps if we sent you those .xml's and you copy them to the phone.
i attached one. get rid of the .txt (i had to add that to attach it) put it in \Application Data\Profiles and see if that works.
File Type: txt Normal.prof.xml.txt (975 Bytes, 5 views)
Old 10-13-2007, 09:55 AM   #5 (permalink)
blazinazn's Avatar
That didnt' seem to work either. anyone else have any ideas I might try. I do not want to do a master reset.
Could someone give me the original order of the profiles under settings\Profiles.
Which profile was
A
B
C
D
E
F
G More...
A
B
Thanks
Old 10-13-2007, 11:37 AM   #6 (permalink)
you couldn't use that profile i posted ? bummer...
Which profile was
A
B
C
D
E
F
G More...
A
B
Thanks
a = normal
b= silent
c = meeting
d = outdoor
e - automatic
f = headset
g = more
(second screen)
a = car
b = speakerphone
Old 10-13-2007, 09:59 PM   #7 (permalink)
blazinazn's Avatar
a = normal
b= silent
c = meeting
d = outdoor
e - automatic
f = headset
g = more
(second screen)
a = car
b = speakerphone
I have everything back to default but yet they still aren't showing up. Any other ideas other than a master reset?
Old 10-14-2007, 08:28 PM   #8 (permalink)
i honestly at this point have no idea... so where did you re-create the profiles ?
Old 11-02-2007, 01:05 PM   #9 (permalink)
KillerQ's Avatar
KillerQ is on a distinguished road
Hey,
Go to connectivetools.com, download switchprofile (demo) use it to change the profile once (just set it to change 1 minute in the future). After that is changed, hold down the homekey, and your profiles will magically return.....
Matt!
KillerQ is offline
Old 11-02-2007, 01:13 PM   #10 (permalink)
Originally Posted by KillerQ View Post
Hey,
Matt!
thanks... but i guess it's a little late :}
