Originally Posted by polishp86 Just wondering, If I do a master reset on a phone that already has Reg. edits on it and installed programs, will the phone still function normally as if I had just bought it from Verizon? Should I perform a reset before activating it with my telephone number? Also, this may seem like a stupid question, but if I do a master reset can I re-hack the phone? If I make a mistake hacking will a master reset fix my mistake and just allow me to start over?
THanks in advance! |
If you do a Master reset it will go back to the way it was when you bought it. This will erase all hacks you have done and any apps you have installed yourself. Yes you can rehack after the master rest.
