Old 11-14-2007, 10:35 AM   #1 (permalink)
a.irish.griffin is on a distinguished road
Default Need help Updating software
Hey guys,
I have been having a keyboard glitch where some key work inconsistantly were others output a slew of wrong letters.... Oh and the "p" sends my text message.
Did a master reset... no good
So I want to install the latest motorola Q update. Active sync is installed with no errors, the update software recognizes my phone, but while installing the progress bar doesn't move.
After 5 minutes or so the update software says there is an error and suggests try powering on and off my phone and repluging the usb cable.
I want my phone fixed please help, do I need to go to the dos prompt screen to install? How can I get this update?
Thanks
Aaron
a.irish.griffin is offline
Old 11-14-2007, 11:26 AM   #2 (permalink)
gump47371 is on a distinguished road
Did you get your phone wet? This sounds very much like more than a needed software upgrade. Hardware of some kind. Still under warranty?
gump47371 is offline
Old 11-14-2007, 01:50 PM   #3 (permalink)
Well, I got the update installed by going into the a+enter flash screen mode then running the software update.
I then installed the smarttoolkit.... worked awsome, soft reboot and the phone is locked down with zero service =(
Just not my day......
So can you do a master reset from file manager?
Old 11-14-2007, 01:54 PM   #4 (permalink)
nm... i got it. My phone is alive again
