Old 07-15-2007, 12:04 PM   #1 (permalink)
jiblue is on a distinguished road
Default need help... low memory
i have a 1 gb storage card but my phone is always telling me it is low on memory. i don't know what i can delete or move to create more phone storage. please help
jiblue is offline
Old 07-15-2007, 12:10 PM   #2 (permalink)
Guerrilla is on a distinguished road
Make sure you're actually using the storage card. Install programs onto your card instead of the device and move files over to the card as well.
Try these:
  1. Use the hacks to move mail and Internet Explorer temp files and cache to the card.
  2. Set your camera to store pictures and video on your card (under options).
  3. Reinstall your programs onto the card (if the card is funtioning correctly in the Q the option will come up asking if you want the app on the device or storage card (default is device).
  4. Clear out your temporary files with something like SKTools or go into IE and clear them out under options.
  5. Move files like music and such over to your card.
Guerrilla is offline
The Following User Says Thank You to Guerrilla For This Useful Post:
Tristan944 (03-01-2008)
Old 07-15-2007, 02:18 PM   #3 (permalink)
Default guerrilla - how do you reinstall programs?
i changed the camera option like you said. i have service thru alltel .... i got the Q 1 month ago. i haven't put hardly anything on it. a little bit of music thats it. i just really want someone to help me utilize my phone.
jiblue is offline
Old 07-15-2007, 02:32 PM   #4 (permalink)
Well those bullet points ar a good start to utilizing your memory. Remember - Music eats up 64MB of user memory really fast.
Old 07-15-2007, 03:05 PM   #5 (permalink)
Default hacks to move ie temp files and cache to the storage card
guerrilla can you help me with the hacks ... and i have read some of your threads and i too have a similar problem. i want to get rid of access shop, active sync, sharpcast photos ect... thanks
jiblue is offline
Old 07-15-2007, 03:33 PM   #6 (permalink)
If you check out the Moto Q Hacks threads at the top of this forum and in Qusers.com's Tips forums you'll find all you eed to know about the hacks. You just need Resco Explorer, PHM or Total Commander (you can find all these here in software) to edit the registry.
Also, I still haven't found anyway to remove those programs completely. The .lnk files are still on my phone.
I can give links later, but it's all easily found.
Old 07-15-2007, 03:39 PM   #7 (permalink)
what programs are you having trouble removing?
Old 07-15-2007, 03:58 PM   #8 (permalink)
Programs installed by AllTel. Problem is a few of the files are System and Read-Only and change back if you remove those properties. I removed the programs. What's left are these shortcuts in the Windows directory, so I don't mind. I figure there's a registry entry I can fool with to change this, but shortcuts don't take up all that much memory.
I just gutted the start menu links and program files with no probems.
Old 07-15-2007, 04:25 PM   #9 (permalink)
Programs installed by AllTel.. Problem is a few of the files are System and Read-Only ad change back if you remove those properties. I removed the programs. What's left are these shortcuts in the Windows directory, so I don't mind. I figure there's a registry entry I can fool with to change this, but shortcuts don't take up all tat much memory.
no they dont...you can try to change the read-only setting in a registry editor and then try to delete
Old 07-15-2007, 05:12 PM   #10 (permalink)
One of these days I'll get around to searching the registry to see.
