Old 05-30-2008, 07:30 PM   #1 (permalink)
Veilside159 is on a distinguished road
Default Need help backing up contacts...
So I had to do a master reset and learned the hard way that your contacts go too... So I entered them all again using my old phone and sim car but I want to make sure I dont have to do this again....
How can I back up my contacts? I know everyone says use active sync and outlook but I cant figure out how to do this... In active sync the option to sync contacts is greyed out and I cant copy the pim file cause it says its in use..
Veilside159 is offline
Old 05-30-2008, 07:43 PM   #2 (permalink)
mike250rs's Avatar
from your Q use the file manager to copy the pim.vol file to "my documents" pc should be able to transfer it from there
mike250rs is offline
Old 05-30-2008, 08:10 PM   #3 (permalink)
still says the same thing...
Old 05-30-2008, 08:13 PM   #4 (permalink)
kill all tasks...then try
Old 05-30-2008, 08:21 PM   #5 (permalink)
same thing..
Old 05-30-2008, 10:22 PM   #6 (permalink)
mike250rs's Avatar
odd....
should be able to explore the Q and just drag & drop
Old 05-31-2008, 02:00 AM   #7 (permalink)
Yea I would think too.... It says the file is in use...
