Originally Posted by PapaPrem I just got my Q last week and theres a couple of quirky issues that I am noticing. First, the backlight on my phone continuously stays on when I am charging the phone (showing the battery indicator). This happens both when the phone is off and charging and also when the phone is on and charging. I also hear a rather audible buzzing sound coming from the phone whenever the backlight is on. Even when I am using it (while the backlight is on.) Is this normal? I tried adjusting the power management settings, as I have everything on "1 minute". However, nothing works.  |
Wow not sure. The buzzing is not normal, however some people have reported it. I suppose it is a preference as to whether you return it or keep it. Mine does not buzz. As for the backlight, double check that you have the setting for AC set to one minute. There is two backlight settings, one on battery and one on AC. If that is set correctly and it still stays on, I would say you have a bit of a bug and you may want to try a reset.
