Originally Posted by scruffy420 I just notice today that when I open a song to play in my Media Player that i can barely hear it. The volume it turned all the way up in the MP but I was wondering if there was somewhere else that I could check or adjust the volume? THANKS |
Found this on another site...
Use a Registry editor and....
"Navigate to
HKLM/Software/Motorola/BPCTRLR/WaveDev/BaseGains
Locate DWORD Value
StereoHdstPathGain
A larger number will specify a higher gain. The system must be rebooted for changes to take effect. For me, the optimum value is 10, but I would recommend raising in single steps above the default to avoid damaging equipment (or your ears). An OS reinstall will most likely revert this setting, so you may have to change it again if you update."
Tried it today... From there you can change the handset, bluetooth, speakerphone, etc. volume... it works!!
