Old 03-08-2008, 08:01 PM   #1 (permalink)
doughboy_2011 is on a distinguished road
Send a message via AIM to doughboy_2011 Send a message via MSN to doughboy_2011 Send a message via Yahoo to doughboy_2011
Default Move contacs to sd card?
Ok. So...i've been having a lot of problems with my q. I don't have any third party apps on it. I only have pics and music on the sd card. I've two qs. The sd card slot died on the first one. and then the second one has been nothing but problems. I've had to take it into the alltel store twice and have it fixed bc it keep freezing at the startup screen just before the screen that says windows mobile. This has had to be done twice. Both at the most inconvenient thing. The only thing that I have lost is all my settings and my contacts. Over two hundred the first time and when i seem to have most of them back this is what happens. I want to be able to have my contacts backed up on the card so that i don't lose them again. Is this even possible?
doughboy_2011 is offline
Old 03-08-2008, 08:15 PM   #2 (permalink)
Geekster's Avatar
Yes, go through file manager and copy pim.vol over to your storage card. I even make a copy & store it on my computer.
I don't have a solution, but I admire your problem.
It's hard to find a Friend who is:
96% Funky
97% Sexy
98% Loving
99% Talented
And
100% Sweet
So...... Don't lose me, okay??
http://www.frappr.com/?a=constellati...d=137440517530
Geekster is offline
Old 03-08-2008, 11:14 PM   #3 (permalink)
or if you happen to use outlook just sync the phone with the PC and you will have your contacts there
OR
you can use jeyo mobile companion
www.jeyo.com
Old 03-24-2008, 12:47 PM   #4 (permalink)
N. Woolsey is on a distinguished road
once i copied them to my sd card i did a master reset, now how do i get them back to where they need to go?
N. Woolsey is offline
Old 03-24-2008, 12:51 PM   #5 (permalink)
copy and paste over the pim.vol file that was created during the master reset
then reboot the phone
Old 03-24-2008, 01:17 PM   #6 (permalink)
still didnt work
Old 03-24-2008, 01:30 PM   #7 (permalink)
ok well the contacts are back up now but now i cant connect to active sync
Old 03-24-2008, 01:32 PM   #8 (permalink)
mike250rs's Avatar
use total commander or resco to copy the pim.vol file from storage card to Q, then reboot
mike250rs is online now
Old 03-24-2008, 01:33 PM   #9 (permalink)
mike250rs's Avatar
may need to delete old partnership and create a new one on pc
