Old 04-27-2007, 02:32 PM   #1 (permalink)
Yester18's Avatar
Yester18 is on a distinguished road
Default MMS stream won't launch
How can I get a MMS: stream to work on my Q.
My buddy is able to get it to launch on his treo. but for some reason it will not launch on the Q using media player.
Any help.
Yester18 is offline
Old 04-27-2007, 02:38 PM   #2 (permalink)
if you are a sprint user MMS will not work as it is not part of there service...only for verizon....
Old 04-27-2007, 06:53 PM   #3 (permalink)
Yester18's Avatar
I'm verizon.
Yester18 is offline
