Old 04-18-2008, 06:51 PM   #1 (permalink)
berdar is on a distinguished road
Default Lock to EVDO
I'm in a area where I'm constantly bouncing back and forth between 1x and EVDO. Is there any way to "lock" the Q to EVDO?
I've searched, but can't find anything.
berdar is offline
Old 04-19-2008, 02:27 PM   #2 (permalink)
##33284# fieldtest menu hdr prefernece
bobby-n is offline
Old 04-19-2008, 08:50 PM   #3 (permalink)
Thanks, but that code doesn't work for me. It dials the number and I get an idiot message saying that isn't a real number.
Any other Ideas? I'm using alltel if that matters.
berdar is offline
Old 04-19-2008, 10:11 PM   #4 (permalink)
Oh SoS is on a distinguished road
Try this one:
##073887*
You'll need your MSL...if you don't have it, you can call your carrier, and they *should* give it to you.
If the above works, then enable the field test menu, and that should enable the "debug" code posted by berdar.
Oh SoS is offline
Old 04-20-2008, 12:29 PM   #5 (permalink)
o yeah i forgot on some phones you have to enable debug mode... this should solve the problem for berdar
bobby-n is offline
Old 04-20-2008, 05:25 PM   #6 (permalink)
Spencer-Scott's Avatar
Spencer-Scott is on a distinguished road
whats the mls?? and if its the same for everyone's is the same does somebody have alltels??
Spencer-Scott is offline
Old 04-20-2008, 06:33 PM   #7 (permalink)
no ever1s msl is different just call alltel an tel them you need it to program your phone
bobby-n is offline
Old 04-20-2008, 06:36 PM   #8 (permalink)
thx bobby
Old 04-21-2008, 01:06 PM   #9 (permalink)
what does msl stand for i went to ask for it for programming and they said theyd never heard of it before... thx
Old 04-21-2008, 01:39 PM   #10 (permalink)
master subsidy lock.. just call them and say that you need to progran your phoe and you need your msl code or service code
bobby-n is offline
