There is no "HACK" per se. I used to do this for my Samsung A900. You have to edit the prl manually. I used to do this to enable data roaming on the a900, however the only problem was you didn't know if you were roaming or not unless you knew your SIDs :-P
But yeah, anyhow, you need a PRL editor, and a way to put it on your phone. |
