It is most definitely beta software and care should be taken but I've not run into a single problem that couldn't be easily fixed.
You should do the opera.ini hack if you go that way:
change the value "Set File Writer Thread Priority=1" to "Set File Writer Thread Priority=0"
I've *heard* Opera may charge ~$15 for it after the beta period but there is no definitive info yet.
