Originally Posted by lovesick101 I just don't wanna go through the hassle of ripping all the songs first to my computer then transferring them to my Q... |
I would hazard to say that this probably your only option, as I have not seen any apps that will allow you to select your Q as a Save as... location, even when connect via ActiceSync.
Your only other option might be if you are planning on having these files on a Storage Card and a have a Card Reader on your PC, you may be able to rip them directly to the card in the Card reader, then insert the card in your Q.
