Originally Posted by cyberdust I just downloaded Pacman. After unzipping it I found 2 files: readme.txt and SPVman.exe. Using the ActiveSync Explorer I copied the SPVman.exe file to a folder on my Q. Using the filemanager on the Q, I clicked and ran the SPVman.exe file and it comes up fine. I can even maneuver it using the cursor paddle.
However, it's really loud and I can't seem to find how to shut off or lower the sound. The wheel on the side doesn't affect the sound level at all.
Anybody get this far and figured out how to adjust the volume? |
I was able to get this far and had the same problem with the volume.
also, i would like to be able to have pacman appear under games just as kevtris does instead of having to have to go through file manager to get to the game. how can i do this?
