Old 04-16-2007, 10:09 AM   #1 (permalink)
Nela's Avatar
Nela is on a distinguished road
Lightbulb Inexpensive fix for hard to use buttons
Am I the only one who hates to use the home,back,calland power keys? They are hard to use, and oftentimes you end up puching the navigation key instead. The only way to accurately use them seems to be with the fingernail, which I'm sure will eventually damage the membrane.
I cam across a sheet of cheap button stickers I bought a long time ago for another phone. They are raised transparent stickers. I used four oval shaped ones to place over those 4 keys.
It is so much easier now!
I am attaching a picture of similar stickers. They look bigger in the picture, but fit nicely inside each slot with room to spare.
They are mostly found in asian stores, and perhaps in cell accessory stores or dollar stores!
Nela is offline
Old 04-16-2007, 10:20 AM   #2 (permalink)
that sounds like a good solution, personally i don't have an issue pushing those buttons with my thumb, but hey if it works for you, more power to you... in the process you may just have helped others who have the issue.
Old 04-16-2007, 10:23 AM   #3 (permalink)
thats not a bad find...do they stick up further than the keys do?
Old 04-16-2007, 10:28 AM   #4 (permalink)
Nela's Avatar
Althought they have a similar feel, they sit slightly lower than the keyboard keys.
If at first you don't succeed....
skydiving isn't for you!
Nela is offline
Old 04-16-2007, 10:29 AM   #5 (permalink)
cool good to know!
Old 04-16-2007, 04:16 PM   #6 (permalink)
Stealth's Avatar
Stealth is on a distinguished road
Very interesting....
Sprint Moto Q user
Stealth is offline
