Old 11-09-2006, 10:55 AM   #1 (permalink)
hellomoto10 is on a distinguished road
Default I don't know how to start a post!
I am posting here because I don't know where I should post.
Is there any way to disable the backlight when it is in a pocket? Everytime I have it in my pocket I expect buttons to be pressed and the backlight turning on and off draining the battery.
Also, I can't get a full day on one charge. Do I have to get the extended battery? Is there a way to disable e-mail or internet to get a longer run time?
Lastly, I have a friend who has a treo. It does not have the backlight issues. I can return my phone for 7 days yet. Should I or do you like your Qs?
hellomoto10 is offline
Old 11-09-2006, 11:50 PM   #2 (permalink)
larsdennert's Avatar
Push home then space.
Turn off IR if it's on. Blue tooth if you don't need it. Set pop to retrieve manually only. If it still sucks battery, try a master reset after sync/backup.
larsdennert is offline
