Old 07-31-2007, 06:01 AM   #1 (permalink)
cincysaab95 is on a distinguished road
Default How to backup items without using Sprite Backup?
How can items on the Q be backed up without using Sprite Backup? I have had my Q for nearly a year and the original one bit the dust last week and VZW sent me a replacement. I've been diligently backing up my Q at least weekly, if not more frequently however, upon trying to restore from Sprite, I've run into a lot of issues namely IE not responding eliminating e-mail etc.
The main things I want to back up continuously are the ringstones that go with many of my contacts. I've had success backing up 3rd party apps to my mini-SD card. Any insight any of you can provide would be much appreciated.
cincysaab95 is offline
Old 07-31-2007, 07:03 AM   #2 (permalink)
use active sync to tkae the tones off your Q and move them to the PC
-Sent from my Q
cincysaab95 (07-31-2007)
Old 07-31-2007, 07:42 AM   #3 (permalink)
^ that, or copy them to your sd card.
Old 07-31-2007, 08:25 AM   #4 (permalink)
Thank you for your assistance. I apologize that I didn't state this previously. I do have everything backed up both on my computer and an sd card however, I don't know what file houses the information for the specific ringtones for specific contacts? If anyone knows, please advise.
Thanks again.
Old 07-31-2007, 08:28 AM   #5 (permalink)
i dont believe it works like that
i sppose you try the pim.vol file but not it stores the ringtones
if you have them saved you will probably just have to reinput them
-Sent from my Q
Old 08-01-2007, 07:25 AM   #6 (permalink)
yea, i believe also you have to reinput the specific ringtones for specific contacts.. look on the bright side, you get to "play" w/ the Q :}
