Old 11-20-2006, 02:48 PM   #1 (permalink)
Lynn is on a distinguished road
Default Help! Setting up 30 phones that don't have data plans
The firm I work for is possibly getting 50 Qs but only giving 20 of them data plans. Is there a way for me to quickly put a phonebook on the remaining 30 that will not be syncing up? Perhaps a 3rd party software of some sort. These units will only be used as phones.
Thanks for the help!
Lynn is offline
Old 11-23-2006, 06:20 PM   #2 (permalink)
pyrobling's Avatar
pyrobling is on a distinguished road
Send a message via AIM to pyrobling Send a message via Yahoo to pyrobling
you should be able to imput everything onto one main computer. prior to setting up the Wireless Sync feature with the data lines you can sync them all to that main computer and have just the contacts sync.
your other options would be to infrared sync your phonebooks from device to device.
your last option is that your B2B rep (business-to-business) should make sure all your needs are covered. since the phonebook entry will be one of them then have the first phone with all the entrys in it phonebook transferred from phone to phone with the machine located at every corporate VZW store. whatever way you choose...it will take a little bit of time but each will get your needed requirement covered.
-adam @ VZW
pyrobling is offline
