Old 01-09-2007, 03:51 PM   #1 (permalink)
jmgrip3 is on a distinguished road
Default Help! Old Yahoo Go Mobile (Non-2.0 beta)?
Help! Yesterday I installed the updated firmware for my Motorola Q, under the assumption I would be able to reinstall yahoo go and sync all my contacts. To my dismay I tried to download yahoo go and they had just announced the 2.0 beta version, which is not supported for the Motorola Q (yet). I really need my contacts back, does anyone have the old version of yahoo go so I can reinstall it? It is not on the yahoo website or anywhere on the web that I can find.Thanks,Joe
jmgrip3 is offline
Old 01-09-2007, 06:14 PM   #2 (permalink)
Pony99CA's Avatar
Default Downloaded Just In Time
If it's not available anywhere any longer, I might have downloaded it just in time. I think I have the version you want, so if nobody else sends you one, E-mail me through my Contact page and I'll send it to you.
Steve
Silicon Valley Pocket PC
http://www.svpocketpc.com
Pony99CA is offline
Old 01-09-2007, 07:08 PM   #3 (permalink)
Default Please send, thanks
Steve,
I contacted you via your contact page. I would really appreciate it if you sent the old yahoo go over.
Thanks,
Joe
jmgrip3 is offline
Old 01-11-2007, 02:47 AM   #4 (permalink)
Pony99CA's Avatar
Default Sent Old Yahoo Go
I sent it yesterday morning. Let us know if it works.
By the way, I suggest doing what I do. I keep an Install folder on my PC where I have all of my installation files. (There are so many that I use nested subfolder categories for them, but it works pretty well.)
Steve
Pony99CA is offline
Old 01-17-2007, 04:28 PM   #5 (permalink)
jgmabler21 is on a distinguished road
I also need the old install. If either of you have it, can you please post it or email it to me.
Thanks
jgmabler21 is offline
Old 01-18-2007, 01:29 PM   #6 (permalink)
Pony99CA's Avatar
Default Did It Work?
So did it work? Give us some feedback.
I tried it on my Q, but it gave me some error. I'm not going to send it out to anybody if it doesn't work.
Steve
Pony99CA is offline
Old 01-18-2007, 06:12 PM   #7 (permalink)
Steve
I think Yahoo reposted the old version of Yahoo Go, I was able to download it again at the following address:
http://sites.mobile.yahoo.com/go/windows
I didn't try the version you sent but the reposted version worked, all my contacts updated seamlessly... what a relief!
jmgrip3 is offline
Old 01-18-2007, 10:01 PM   #8 (permalink)
i used the link that was posted and it worked great. thanks
