Old 01-29-2007, 01:50 PM   #1 (permalink)
lsherwood32 is on a distinguished road
Default HELP - Need to delete All Contacts
Is there a way to delete all contacts without completely resetting the phone?
Thanx
LS
lsherwood32 is offline
Old 01-29-2007, 01:51 PM   #2 (permalink)
tj!2k6's Avatar
tj!2k6 is on a distinguished road
Thanx
LS
I don't know if you can delete them all in one shot from the Q, but you could delete them in Outlook and then sync the phone. That should take care of it...
If you found a post useful, let the poster know by adding to their rep:
<-- click on the pic below their avatar in the left-hand column.
tj!2k6 is offline
Old 01-29-2007, 02:01 PM   #3 (permalink)
Thanx, can I save the contacts first, then remove them, sync, and then put them back?
Old 01-30-2007, 10:38 AM   #4 (permalink)
tj!2k6's Avatar
Dunno the answer to that one.. just curious as to why you want to delete all contacts in the first place..?
tj!2k6 is offline
Old 01-31-2007, 02:07 AM   #5 (permalink)
larsdennert's Avatar
Create another contacts folder on the PC and move your contacts there. Sync and they will disappear from the Q.
http://www.larsdennert.com
larsdennert is offline
