Not quite sure what you mean... if you are referring to sending a text msg, then go to Start, Messaging, and select Text Message.
I'm sure the manual accompanying the Q can give you more details.
Originally Posted by ezprofess4 Can someone please point me in the right direction to find information on learning to text using a q on verizon... what software, etc? Thanks |
