Originally Posted by hnsimpson Have you tried the "take out the battery and wait, then reboot"?
Also, try turning the Q on while you hold down the D-pad center button.
If this doesn't help, reply with a description of what happens when you boot.
-Simpson |
thanks I was going crazy, my phone would just get to the motorolla image upon boot up and freeze.
After holding the d pad center button down and turning it on I performed a master reset and now it works, thanks!
It was my fault it got messed up to begin with, was following some instructions on trying to see youtube on the phone and replaced some window files on the device.
thanks agian.
