I am having the same problem. Some of my ringtones are not playing. They are in the right spot, normal setting with volume = 4. They do play using windows media player.
What gives? Are the ringtones limited in size maybe?
Thanks for the help!
BTW I tried searching problem to no avail.
Originally Posted by JoshD I am making my ringers about 30 seconds long with a MP3 editing software. They play fine on the PC. I put them in the Sounds folder. When I go to select my new ringer and sample it to see how it sounds it wont play. It just clicks. Now, I can set it as then ringer and when somone calls it plays. Anybody else find this odd? Do you guys have any suggestions?
Thanks |
