Old 04-16-2007, 03:28 AM   #1 (permalink)
iLLuSi0nS is on a distinguished road
Default Having First names first
Is there a way of having the first name first and last name second for your contacts.
First name Last name instead of Last name, First name
Thanks
iLLuSi0nS is offline
Old 04-16-2007, 07:10 AM   #2 (permalink)
scubasteve's Avatar
scubasteve is on a distinguished road
Yea, type them in the opposite field
scubasteve is offline
Old 04-16-2007, 07:29 AM   #3 (permalink)
michael.egan is on a distinguished road
Yeah, you could do that, or you could type the info in backwards and hold your Q upside down and read the screen through a mirror....
Perhaps a more elegant approach would be :for each contact, scroll down almost to the bottom of the contact screen, past all that stuff you'll probably never fill in and select "File As" and select the filing format you want....
michael.egan is offline
Old 04-16-2007, 08:05 AM   #4 (permalink)
scubasteve's Avatar
no need to be an ass.
Old 04-16-2007, 08:06 AM   #5 (permalink)
Need Help
Thanks
yes, it is possible with a little program called Contact Changer, you can find it here: http://www.shubaroo.com/index.php?module=contact
Old 04-16-2007, 08:36 AM   #6 (permalink)
bhall is on a distinguished road
I just my Q last week and had the same problem with entering in names and numbers into my Contact list. There is a way on the Q when entering the information to make the First name appear first and last name last. (First / Last Names) You dont need any software for this. Just a feature in the Q it self.
When you go to add a new contact to your list, fill in the first name field, and then the last name field. Scroll down to the phone number fields and fill in the ones you want. From there, continue to scroll down. Scroll down to you see "File As" at this point you can make a choice between Last name first or first name first. Click done, and when you go into Contacts it will appear with first and last name.
I hope this information works out for you. I'm new to the Q as well and have been playing with it all weekend. I notice that little features and tips like that Motorola failed to included them into the user manual. Lots of helpful hints on this website.
Good Luck
Motorola Q User
bhall is offline
Old 04-16-2007, 09:23 AM   #7 (permalink)
hahahha, When i posted this issue i had owned the phone for less then an hour and i didnt want to post that i was a newbie, but obviously it shows.
Thanks to you guys i got it figured out, thanks guys
Old 04-16-2007, 09:24 AM   #8 (permalink)
no problem, we all had our first day (and hour :} with the Q...
Old 04-16-2007, 09:40 AM   #9 (permalink)
hanski9's Avatar
hanski9 is on a distinguished road
Send a message via AIM to hanski9 Send a message via Yahoo to hanski9
on problem, we all had our first day (and hour :} with the Q...
RB, I thought you were born with a Silver Q (instead of the spoon) in your mouth. LOL
What's it gotta do besides ring?
Accessories: Moto H700 BT, Garmin Mobile 10, 4Gb Qmemory miniSD
hanski9 is offline
Old 04-16-2007, 09:58 AM   #10 (permalink)
Smile
whahahahahahahhaha.... you guys kill me
