Old 09-15-2007, 04:03 PM   #1 (permalink)
craigslist is on a distinguished road
Default General Questions about Q shortcut/features
I just got my Q from sprint and I love it. But there are still a few things I found lacking compared to my 3-year-old nokia. Can some1 let me know if those are doable in Q?
Complaints ;)
1) Automatic keypad lock. If you don't press a key and not in a call for so long, it automatically locks your keypad
2) record a call by pressing a button
3) set up a phone card for calling international #s. I know you can insert the full phone card # in the contacts, but if your card # expires, you'd have to update all contacts. Is there a way to insert a phone card # and just "long press" a contact and it will dial the contact with the phone card?
4) this really anonies me, the text msg/email program keeps opening itself in the background, even after I killed it, it will reappear in the running program list after awhile. This has the effect of lighting up the screen every minute or so, and I think that's why my battery is drained in 12 hours.
5) Assigning a voice-dial to a contact (by saying it in your own voice once), instead of relying on the voice recongnition software which is terrible with foreign names.
Questions
4) I heard windows live search and google map can make use of the internal GPS, however, I've never been able to get it work. Any hints?
craigslist is offline
Old 09-15-2007, 07:32 PM   #2 (permalink)
Pony99CA's Avatar
Default Phone Differences
I believe there's a program to do automatic keyboard locking, but it's not standard.
However, you can do automatic device locking if you set a password on your device. Go to the Security settings applet and choose Device Lock. You can select a time interval to wait before the device locks.
No. Again, there may be third-party software to do this, but I'm not sure if it works on the Smartphone platform.
Not that I know of. I've see a registry entry that allows changing your location, so you could theoretically set it to dial things like "9" or "1", but I don't know if that works.
Stop killing it. If you've configured E-mail to check automatically, it's supposed to be running.
I never kill E-mail and have it check my account every 30 minutes. I generally get a full day's use out of it (although I don't tend to make many calls).
As far as I know, there's no way to add voice tags to contacts. (I can't even get the Voice Recognition program to recognize when I say "Yes", even though it's pretty good with names.)
That's not true. You need an external GPS receiver; the one inside the Q is only an aGPS receiver.
Steve
Silicon Valley Pocket PC
http://www.svpocketpc.com
Pony99CA is offline
Old 09-15-2007, 09:41 PM   #3 (permalink)
Complaints ;)
check here for Automatic Keylock..
