Originally Posted by duderalph_2005 I tried that already. After about a minute or so the lights start flashing on that screen too.  |
This happened to me TWICE in two days and two different phones.
I did some research and it's a memory allocation issue. If you go to Start -> System Tools -> Memory Manager and look at device storage it is SUPPOSED to say 51.82mb, but a lot of phones that were built after September of 2007 say 5.88mb, but that extra .6mb is not there, so the phone is trying to write information to memory that is not there, resulting in a lock up.
What you have to do is, pull the battery press and hold the center button in the D-pad and the red power button and insert the battery. Your going to lose everything unfortunately. THEN after it goes into the phone, it will still say 5.88 and you have to do a master reset from within system tools and THAT will fix it.
I almost hated the Q and abandoned it because the Alltel guys are tools and were going to just keep giving me new ones.
I even went back and tried to show them for their future reference and they were assholes about it.
Do this and it will fix your problem
