Originally Posted by daniel if you try searching for "battery" you will find many threads that answer the question you just posted ;) |
While searching is a good idea, answers like this flaw the search option.
Yes, the extended battery does make a world of a difference. Depending on which battery you go with, depends on how long it lasts.
