Old 03-13-2007, 01:47 PM   #1 (permalink)
Voity is on a distinguished road
Default EVDO/1X Connection keeps failing
Trying to stream either SIRIUS radio or internet radio and my WMP/TCPMP keeps cutting out almost a minute after starting saying that i am not connected to the network. However, IE works fine with no probs. any suggestions?
Voity is offline
Old 03-13-2007, 02:47 PM   #2 (permalink)
inf3st's Avatar
inf3st is on a distinguished road
what happens when you resume the connection? I used to have this problem and when i resumed it or retried it, it worked fine. Usually because of bad signal.
Dustin
If somebody helps you, boost their reputation. Click the Reputation icon under their user name.
inf3st is offline
Old 03-14-2007, 10:53 AM   #3 (permalink)
that has to be it. i keep loggin back in and it keeps cutting out. i have switched between EVDO and 1X to no avail. there is no way to check your signal strength for data is there?
Voity is offline
