Old 08-23-2007, 09:57 PM   #1 (permalink)
zone97 is on a distinguished road
Default Enable Phone Lock
I just got a new motorola Q black, not the q9m, and under start > settings > security there is no Enable Phone Lock, why? the online manuals and faq say there should be... has this feature been removed in an recent update? Could there be a third part app that does the same thing?
Thanks.
zone97 is offline
Old 08-23-2007, 10:01 PM   #2 (permalink)
Thanks.
i have an option under security called device lock
you can also hold down the home key and see if you have anything there that says device lock (which you should)
Old 08-23-2007, 10:04 PM   #3 (permalink)
MOL3 here, under Security i have: Device Lock and Certificates.
Quick list: also Device Lock.
Old 08-23-2007, 10:13 PM   #4 (permalink)
Should have looked first... Found this thread.
http://www.everythingq.com/forum/mot...lock-6693.html
with this link in it...
http://maniac.fschreiner.de/index.ph...id=8&Itemid=19
nice little app to fix my missing auto lock feature.
zone97 is offline
Old 08-23-2007, 10:15 PM   #5 (permalink)
so you dont see that options in either of the menus that RB and i listed?
