Old 06-07-2007, 10:43 PM   #1 (permalink)
motoxkid478 is on a distinguished road
Default Email (0) help
I took a quick look but couldnt find anything on this.
How do i set it up so it shows my emails on the home screen where its
Email(0) text messages (0) instead of it popping up below like so
gmail(23)
hotmail(34)
Also i thought i saw a way to set my hotmail to auto update mail but couldnt seem to find it again. i am a verizion user i dont know if it makes a diffrence thanks a bunch!!!
Eric
motoxkid478 is offline
Old 06-08-2007, 07:26 AM   #2 (permalink)
try searching for "counter" or something... it has been discussed a few times and most likely your issue is that the .xml is using the wrong plugin.
Old 06-08-2007, 09:27 AM   #3 (permalink)
RFI4U's Avatar
RFI4U is on a distinguished road
Send a message via MSN to RFI4U
The issue is that the plugin you are using to check the email is only checking your activesync and not individual pop3 accounts you may have programmed in the phone.
The xml for the plugin should look something like this based on your description:
<plugin clsid="{62E5C279-1E55-4bbb-95DA-D576093C23BE}" name="MessageCount" height="20">
<background>
<format state="selected" bgcolor="COLOR_HOMEHIGHLIGHT"/>
</background>
<label>
<text lang="0x0409">Email <unreadMsgs name="ActiveSync" /></text>
<text lang="0x0C0A">Email <unreadMsgs name="ActiveSync" /></text>
</label>
If you change the line:
to:
<text lang="0x0409">Email <unreadEmail /></text>
The Email counter will show the count of all POP3 + ActiveSync
Hope that helps
RFI4U is offline
Old 06-08-2007, 11:07 PM   #4 (permalink)
<background>
</background>
<label>
</label>
to:
Hope that helps
Im not to smart when it comes to things like this. how do i get to this so, can change it so i have to explore phone through active synce if so were do i go to get to that point to change it?
Old 06-08-2007, 11:53 PM   #5 (permalink)
\application data\home folder and find the .xml file that you are using
Old 06-09-2007, 06:27 PM   #6 (permalink)
nags's Avatar
nags is on a distinguished road
Send a message via AIM to nags
I just did that to a T and it's still not showing the mail count on the main screen. I'm using the default sprint layout and modified sprint.home.xml. Thats correct, isn't it?
http://www.the-nags.com
nags is offline
Old 06-09-2007, 06:30 PM   #7 (permalink)
post up your xml code for the message counter
edit: make sure you restart your homescreen or it wont take effect
Old 06-09-2007, 06:30 PM   #8 (permalink)
nags's Avatar
I think I may see the problem. I'll post back in a bit.
nags is offline
Old 06-09-2007, 06:38 PM   #9 (permalink)
nags's Avatar
I need something to edit an xml file with.. Notepad doesn't seem to be doing it properly...
nags is offline
Old 06-09-2007, 06:40 PM   #10 (permalink)
nags's Avatar
Ok, finally got notepad to do it. What a pain in the ass! Waiting on an email to come through now to test it out
nags is offline
