So the Guru and the Evangelist weren't up to it, but thanks to GldnBear I have a great test I can perform.
I already had Bell Tier 2 tech support perform a test where they emailed me a message with a 1MB attachment to see how the data transmit appeared on their end. The end result was one 1.5MB data transmit which equaled the message plus the attachment plus a few kilobites. This was when I had the phone set to download the entire message (though this still shouldn't have included the attachment and Motorola's manual agrees), now I have it set to only download the first 5K, but it did show that the Q was also downloading the attachment (one of my arguments at the time before switching to the 5K workaround), the message, and 3-4KB extra.
The problem I have been having is I have no way to figure out where this extra data is coming from, but GldnBear has suggested an excellent test.
Thanks - I'll post my results. I've also made two changes to my email account on the phone, now I have the account set to IMAP, and to only download the last 7 days of messages and the headers only (every 30 min).
If anyone's interested, I have another issue now (see forum topic: deleted messages do not delete from IMAP, or something like that). Now messages I delete from the Q are not being deleted from my IMAP server and the message is re-downloaded, but now marked as read instead of just being deleted or being moved to a deleted folder (trash bin)
Originally Posted by GldnBear I believe you can track your data usage. You can try turning off your e-mail checking and check the usage to see if some other program is using your data. You should be able to correlate the amount e-mail downloaded versus total usage to get a feel for the overhead. Data also has error checking, so if data doesn't agree, it will have to resend parts of the download. There is also some header information sent with each piece of data.
I have an unlimited plan, so I do not know how the carriers define what is data usage. If it includes overhead and error checking, you may be using a lot more than you think. |
