Originally Posted by nifaron ##073887* (send) When prompted to “Enter Security Code” type: 475593 That should work - |
actually you are only half right. ##073887* is the code to access the programming menu. spc code is unique to the phone. when you first get the phone from the factory the spc is all 0's but once you do the PRL update, *228, it is likly that the spc code will be changed to a code unique to your phone. this is not always true though, my phones is still 000000.
also on a side note. you should do a PRL update to your phone every so often. this will put new towers into your phones list of towers.
Zach
