Old 06-19-2007, 01:07 PM   #1 (permalink)
cschauer is on a distinguished road
Default Charging Indicator Beep
When I plug in the Q, it gives me an obnoxious beep, is there anyway to shut that off or lower it so it doesn't disturb my newborn when I plug it in in my bedroom at night?
cschauer is offline
Old 06-19-2007, 01:12 PM   #2 (permalink)
this has been asked recently and no one has figured out a fix to that yet...
Old 06-19-2007, 01:34 PM   #3 (permalink)
Smile
the only remedy at this point is something Scott ^ does when he plays games under work time, he puts duct tape on the speakers :}
Old 06-19-2007, 01:36 PM   #4 (permalink)
hahahaha you cant proove that!
Old 06-19-2007, 02:08 PM   #5 (permalink)
25bbmom is on a distinguished road
Go to Profiles. Select the Profile that you are using. Hit the Menu soft button. Select Edit. Go to the last option that says System Sound Volume, turn it off. That will make the beeping stop when you plug and unplug your phone.
25bbmom is offline
The Following User Says Thank You to 25bbmom For This Useful Post:
lbmmoh (01-28-2008)
Old 06-19-2007, 02:12 PM   #6 (permalink)
well look at that...learn something new everday (as RB says)
Old 06-19-2007, 02:15 PM   #7 (permalink)
yep, goes for me also...
(and no, i can't prove that.. yet :}
Old 10-27-2007, 01:18 AM   #8 (permalink)
Accordman is on a distinguished road
Send a message via AIM to Accordman Send a message via Yahoo to Accordman
is there a way to change it to a different sound?
Accordman is offline
Old 10-27-2007, 11:06 AM   #9 (permalink)
if you turn system sounds off it may be silent. to change it find te sound in the Windows directory and replace it.
posted on the Q.
Old 10-27-2007, 12:43 PM   #10 (permalink)
winotree is on a distinguished road
I might just be a crazy old bachelor (and don't take this the wrong way) but hasn't your baby been hearing that "beep" for the past nine months? ?
PS You can always mute the phone...
winotree is offline
