Old 06-11-2007, 11:41 AM   #1 (permalink)
glchism is on a distinguished road
Default Body Glove
I just order the Body Glove cellphone case for the Q throught Verizon. Does anyone know whether this case is compatibale with the extended battery? If you own the case, can you tell me how you like it?
glchism is offline
Old 06-11-2007, 12:01 PM   #2 (permalink)
most tight fitting cases do not fit with the extended battery...
Old 06-11-2007, 12:23 PM   #3 (permalink)
BigOrange's Avatar
BigOrange is an unknown quantity at this point
Have you seen it? The one I saw had some clear plastic stuff over the keyboard, which is not very fun to work with.
BigOrange is offline
Old 06-11-2007, 04:03 PM   #4 (permalink)
schism is on a distinguished road
I got one last week. The screen is covered, but not the keypad. Its a decent case. It edge of the screen protector sits right above the left/right softkeys and up arrow, so its a little awkward hitting them sometimes.
I don't have an extended battery, so I'm not sure if it will fit or not. It seems to have a little room to stretch, but I haven't seen how big the ext battery is.
This is actually the first case I've ever bought because the Q was the first phone I've owned that really needed one. so my opinion of it might not be valid.
schism is offline
Old 06-14-2007, 09:48 AM   #5 (permalink)
sjcruiser36's Avatar
sjcruiser36 is on a distinguished road
Default Happy with Q Body Glove
I have had the Body Glove for the Q for a couple months now and it works great. I don't think an extended battery will work with this case. The keyboard is not covered. The only issue I found is that I have to clean under the screen covering every few days.
sjcruiser36 is offline
Old 06-14-2007, 12:14 PM   #6 (permalink)
i got the body glove yesterday and returned it the same day because it did not fit the extended battery. thanks for your response.
glchism is offline
