Originally Posted by ZATZAi It's possible to drain a Li-Ion battery to the point that you can't recharge it, Li-Ion's never really get fully drained when they are "dead". Li-Ions need a 3.7volt charge or so I believe ideally, using less than that can have a negative effect...
I'm not real clear on the numbers, there are some white-papers on it out there you can read, you may be able to recover your battery still if you charge it directly, or try an AC charger (But it could take a good while). You'll have to do some research. |
I recovered them, but the real question is"Why did this occur?"
