Old 04-17-2007, 11:36 AM   #1 (permalink)
blachole is on a distinguished road
Default Auto Key Lock?
Is there a way to have the phone auto lock the keys when the back light turns off? I keep putting it in my pocket and keys get pressed. I do not want to use a security code to unlock the phone each time.
blachole is offline
Old 04-17-2007, 11:38 AM   #2 (permalink)
either the pass key or hold down the home key and hit key lock...all you have to do to bring it back up is hit the 'unlock & * key'
Old 04-17-2007, 11:40 AM   #3 (permalink)
Yes, I want this feature, but only for it to do it automatically after say 5 minutes of inactivity.
blachole is offline
Old 04-17-2007, 11:43 AM   #4 (permalink)
that function you have to do manually...im not sure it will do that if the screen turns off...i usually do this before i put it in my pocket
Old 04-17-2007, 11:44 AM   #5 (permalink)
or i suppose you can use the password one and just use the * key as your password and set it for a few seconds to go to autolock
Old 04-17-2007, 11:51 AM   #6 (permalink)
jmlg is on a distinguished road
Actually I am using a program called "automatic keylock"
http://maniac.fschreiner.de/
It works pretty durn well.
jmlg is offline
The Following 3 Users Say Thank You to jmlg For This Useful Post:
bothersomeaunt (07-02-2008), daveoman1 (08-13-2008), Shad0wguy (07-08-2008)
Old 04-17-2007, 11:56 AM   #7 (permalink)
just downloaded it and going to give it a look see
Old 04-17-2007, 12:03 PM   #8 (permalink)
Good thinking, but the password has to be at least 4 digits. It has a manually key lock built in, I can't understand why I can get it to work the way I want. Every other phone I have had does it.
blachole is offline
Old 04-17-2007, 12:05 PM   #9 (permalink)
yea i know what you mean...i just tried that program and attempted to run it and it gave me an error message....
i just uninstalled it and will try again later on...
Old 04-17-2007, 12:16 PM   #10 (permalink)
Perfect! Thanks a ton!
blachole is offline
