HA! Got there myself.
Note to the Forums: I found a million posts saying that I would need a registry editor and where to get it, but there is really no step-by-step tutorial for noobs. Like "What files to copy from your PC" and "Where they should go on your phone" etc.
This is how I did it and I got it to work.
First I needed a Registry Editor (PHM worked for me...I ran the EXE and then copied all of the .CAB files to my My Documents folder on my phone, then ran them one at a time until "
regedit.Stngr_ARM.CAB" worked for my Q. Then the PHM Registry Editor just appeared as one of the options when I go to my Start menu.)
Then I started PHM Registry Editor (on my phone) and navigated to HKey_CURRENT_USER\ControlPanel\Sounds\RingTone0
hit "Values"
navigated to "Script"
and in the "Value Data" it said "c50apw3c150r" which (I think) translates to:
Regular Volume = 50%
Ring once
Wait (Pause) for = 3 seconds
Ring again at increase of 150%
Repeat
I changed it to "c50apw0c150r" (meaning that I wanted it to pause for zero seconds) and it works awesome. It doesn't exactly "loop" seamlessly, but it does allow enough rings so that the volume increases and I can hear it in my car.
There are some good examples for another phone/PDA Here (under "Phone Settings" and listed below) and similar information Here (which as of Jan. 13 is not linked correctly on the first page of the Hacks topic).
Phone Settings
Phone Ringtone Script [HKEY_CURRENT_USER\ControlPanel\Sounds\RingTone0]
Change the value of "Script"
Here's the code:
a - stands for display
r - repeat/replay the script again
c - sets the volume C50, c150, c100
f - means flash .. f1 flash for 1 second and f0 stands for flash continuously
p -means play ringtone
v- vibrate then incorporate with number to state how many seconds it will vibrate example. v3 vibrate for 3seconds or v0 for continous
w - stands for wait or pause then specify how many seconds like w3(wait for 3 seconds)
Here's an example:
Flash - af1w60f0
Ring - apw3r
Ring Once - ap
Increasing Ring - c50apw3c150r
Vibrate Then Ring - v3w3apw3r
Vibrate - av3w3r
Short Vibrate - av1w3r
Vibrate Long Then Ring - v3w3v3w3apw3r
Vibrate And Ring - av0pw3r
Increasing Ring And Vibrate - c50apv3w3c150r
Fast Vibrate And Flash - af1v1w1f0r
Vibrate and Ring Continously without pausing - av0pr[/b]
