Old 11-17-2007, 05:28 PM   #1 (permalink)
Camille2308 is on a distinguished road
Default ActiveSync Not Working
my active sync isnt working. When i connect my phone (via USB) it recognizes it, and quickly disconnects. I tried deleting and redownloading the software, but that hasnt worked.. I would also restart my computer and phone, and that hasnt worked either.. is there anything else i could try?
Camille2308 is offline
Old 11-17-2007, 05:48 PM   #2 (permalink)
Default Moved
--moved to MotoQ forum--
have tried to delete the partnership in active sync and then try to resync?
Old 11-17-2007, 06:11 PM   #3 (permalink)
yes, i tried that.. there are no partnerships when i open activesync from my phone... and it still isnt working...
Old 11-17-2007, 06:18 PM   #4 (permalink)
on your PC delete the partnership not the phone
Old 11-17-2007, 06:28 PM   #5 (permalink)
....still nothing.
Old 11-18-2007, 06:19 AM   #6 (permalink)
Does the phone charge on a regular outlet?
You may have a bad USB cable, or the connections need to be cleaned. In addition, Microsoft has released newer versions of ActiveSync, so you may want to surf the MS site to see what upgrades are available.
Der Alta is offline
Old 11-18-2007, 01:46 PM   #7 (permalink)
khuas is on a distinguished road
Do you have a software firewall installed?
khuas is offline
Old 11-18-2007, 02:21 PM   #8 (permalink)
my USB cable is fine.. i have a couple of them...
i think i have the latest version of active sync.. i have.. 4.5.0 5096 (something like that)
my phone recognizes its connected to a power source when connected to the computer.. all the settings are correct.. i cant figure out why it isnt working though.
Old 12-04-2007, 02:52 PM   #9 (permalink)
Jaz66's Avatar
Jaz66 is on a distinguished road
I do have the same problem... The computer sees the phone, but not my ActSync software. I'm quite sure the problem comes from my firewall (everthing was fine before I installed AVG internet security suite), but I don't manage to configure it correctly. All connections needed by ActSync are permitted on AVG firewall, but it doesn't seem to help!
Anyway, I suggest you check your firewall settings (and I hope for you they aren't has complicated as mine!!)...
On the other hand, if anyone can give me a tip with AVG, I would be thankful...
__________
Jaz66
*if u want, take some time to visit my band's website*
Jaz66 is offline
Old 07-16-2008, 08:17 AM   #10 (permalink)
ajit_kane is on a distinguished road
Default Simple solution
In your connections settings uncheck the advanced USB connection functionality check box. That should do it
ajit_kane is offline
