Old 10-15-2007, 04:27 PM   #1 (permalink)
GeeUnwired is on a distinguished road
Exclamation ActiveSync 4.5 Issue
A while back I upgraded ActiveSync on my PC to 4.5. Afterwards, my PC didn't recognize that it had a partnership with my Q so I had to reaccomplish. Here's where it gets interesting. When I did that, ActiveSync told me that it was already set up with another PC so I had to rename this PC (the same machine) something different. But it wouldn't let me change or reaccomplish any of the existing settings. It did, however, let me set up a partnership with "Windows PC"...now I have two; one with my contacts and the other with everything else. I can sync everything else but my contacts haven't been synched in over a month. How do I uninstall the previous Activesync from my Q so I can start over? Or is there another way?
GeeUnwired is offline
Old 10-17-2007, 02:28 PM   #2 (permalink)
mwitzah's Avatar
mwitzah is on a distinguished road
Hmmm - did you try deleting the old partnership instead of worrying about the new Active Sync? If you delete the old partnership and then reconnect it might transfer all the new info in the NEW partnership. Sounds like a problem I had that deleting the old partnership fixed. I had many unused partnerships at one point from all the replacement Q's I got . . . just make sure before you try that that whatever info you have is located on your phone or on Outlook & can get synced amongst the two upon the new partnership.
My two cents, hope it helps!
Witzah
mwitzah is offline
