Old 03-13-2007, 02:53 PM   #1 (permalink)
gMarquezTwo4 is on a distinguished road
Default Active Sync Wont Recognize Q... Please Help
I've searched the forums and read a few Active Sync threads but couldn’t find anything to fix my problem.
I have updated to Active Sync 4.5. When I connect my phone to my comp (using USB) the phone will charge and my comp makes a sound like it recognizes something being connected. For whatever reason my phone still won’t connect to Active Sync.
I even tried removing all relationships from Active Sync on my phone.
Do you guys have any idea what this is or how I can get my phone connected to Active Sync? I'm pretty sure everything is up to date.
Thanks
gMarquezTwo4 is offline
Old 03-13-2007, 05:21 PM   #2 (permalink)
SteveBrady is on a distinguished road
Check your firewall settings. Go to
http://www.microsoft.com/windowsmobi...c/default.mspx
SteveBrady is offline
Old 03-13-2007, 07:22 PM   #3 (permalink)
Sniperet is on a distinguished road
In ActiveSync go to File/Connection Settings and ensure "Allow USB Connections" is checked.
With your phone disconnected from the USB cable go to settings/Connections/USB to PC and ensure "Enable advanced network functionality" is checked. Go to Start/ActiveSync/Menu/Options and highlight any connections shown click menu and delete them.
When you reconnect to the PC and start ActiveSync should bring up the new connection setup windows.
Sniperet is offline
Old 03-14-2007, 03:35 PM   #4 (permalink)
On my phone, when I go to Settings/Connections... the only options available are A: Beam and B: VPN. I don’t see an option for USB to PC. Could I have deleted something?
Old 03-14-2007, 04:17 PM   #5 (permalink)
pyrobling's Avatar
pyrobling is on a distinguished road
Send a message via AIM to pyrobling Send a message via Yahoo to pyrobling
Go into ActiveSync option on the phone and click on Menu when disconnected and click Connections.
Make sure it is enabled.
Then make sure there is no relationship established in the phone...delete if there is. Next go to File and Mobile Device...if something is there go to File and then Delete Mobile Device and you should be able to reconnect.
-A
ADAM in Oregon
Text JOIN EverythingQ to 8762 to join Upoc's EverythingQ group
pyrobling@gmail.com
blingsthing.blogspot.com
blingselectronics.blogspot.com
......electronics reviews
If someone helps you thank them, use the icon under their post
pyrobling is offline
Old 03-14-2007, 04:24 PM   #6 (permalink)
-A
Do I do this on my phone or computer? Thanks for the help.
Old 03-14-2007, 04:56 PM   #7 (permalink)
pyrobling's Avatar
yeah the ..... part was supposed to be there part where you look on the computer. everything after .....so on the comp.
ADAM in Oregon
pyrobling@gmail.com
