A little help... Ok I recently converted from Treo 650 to Motorola Q. I like the phone, but I have a couple of issues that I need to get resolved:
1. I am have a irritating activesync problem. I am activesyncing with my home laptop and my work laptop. When I sync at work it crashes when it comes to the calendar. It gives me the following error, "The instructions at "Ox7c350440" referenced memory at "0x000000000". The memory could not be "read". The strange thing about this if I uninstall/reinstall activesync a couple of times it works, but when I go home my home activesync does not work. I have to repeat uninstall/reinstall activesync at home to get that to work.
2. I really liked how the txt message worked on the treo 650. I downloaded txtman and it is close. Does anyone know if you can get emoticons on it?
3. Is there a quick way to pull up call history? Also, can you change the view so you can see the timestamp of a call without having to open it?
4. I used verichat on my 650, I downloaded verichat for smartphone but its is nowhere close to the functionality of the version for the 650. Does anyone know of a better IM Chat program? |
