Old 03-06-2007, 12:51 AM   #1 (permalink)
Banned
hawkim is on a distinguished road
Default a font problem
i downloaded a trial of "city time alarms" and when i tried to change the style of the alarm on that program, it changed the font on all my folders to an LED looking font. i hate that font, my question is, how to change the font of the names of the folders and their contents back to the default font. please please help....aaaahhhhhh!
hawkim is offline
Old 03-06-2007, 08:28 AM   #2 (permalink)
how much 'personalization' have you done to the phone ? else maybe a master reset ?
Old 03-06-2007, 09:36 AM   #3 (permalink)
inf3st's Avatar
inf3st is on a distinguished road
try uninstalling the program first. see if that helps
Dustin
If somebody helps you, boost their reputation. Click the Reputation icon under their user name.
inf3st is offline
Old 03-06-2007, 10:30 AM   #4 (permalink)
Banned
not much, i did add a few programs to the phone (that it needed) but not much on my own personalization, like registry stuff, which i know nothing about. and if i did a master reset would i have to install all the programs again. and if they are already installed in the active sync will that program im trying to get rid of be re-installed. thanks for all your help.
hawkim is offline
Old 03-06-2007, 10:34 AM   #5 (permalink)
installed programs need to be re-installed after a master reset. did you try to un-install the program as suggested ?
hope this answers your question.
Old 03-06-2007, 10:45 AM   #6 (permalink)
Banned
i did uninstall the prog. but there was still an icon, so i did a soft reset, the actual icon is gone but i still have a sort of generic icon with the name of the prog. i se a master reset in my future. thanx
hawkim is offline
Old 03-06-2007, 12:08 PM   #7 (permalink)
Smile
almost my exact words from last week (without the typo :}... a master reset ain't that bad, i was back to where i started minus the issue why i did a reset within about an hour and a half, and hey there are worse things then "playing" with your Q for an hour and a half :}
Old 03-07-2007, 07:46 AM   #8 (permalink)
inf3st's Avatar
Are you seeing that icon on your homescreen? If so it will go away as you use other programs. Also. When you uninstalled the program did it fix the font problem?
Dustin
inf3st is offline
