Old 08-08-2006, 07:18 PM   #1 (permalink)
bostonfan23 is on a distinguished road
Default A Few Questions from a Noob
hi, first of all, i have to say I bought my Q yesterday and I LOVE IT! No regrets whatsoever yet. It's great.
Anyways, i'm running my Q on a Mac. I have MarkSpace and all that.
a.) how can I get AIM on it for free?
b.) why isn't my gmail working for it?
c.) why do square images stretch when I set them as a background? can i change that?
d.) is there any freeware anybody reccomends?
e.) how can i easily lock the phone? how about turn down the volume?
f.) finally, ringtones. how do i get new ringtones?
thanks!
bostonfan23 is offline
Old 08-08-2006, 07:46 PM   #2 (permalink)
tj!2k6's Avatar
tj!2k6 is on a distinguished road
well.. let's see.
a.) agile messenger seems to work fairly well.
b.) it works. follow the tutorial here: http://www.everythingq.com/kb/how-to...-a-motorola-q/
c.) you could try editing them to be 320x240 before putting them on the Q
d.) here are some apps others are using: http://www.everythingq.com/forum/sof...our-q-452.html
e.) to lock the phone, hold down the Home button. To change the volume, hold in the scroll-wheel until the volume indicator pops up, then rotate the wheel.
f.) you should be able to use any wav as a ringtone.
edit: Forgot to mention.. there is also a Mac forum, so you might want to check the posts in there to see if/what/how things work when interfacing with a Mac: http://www.everythingq.com/forum/mac-motorola-q/
tj!2k6 is offline
Old 08-08-2006, 08:04 PM   #3 (permalink)
thanks! i'll try those!
Old 08-11-2006, 12:20 PM   #4 (permalink)
flyboym535i is on a distinguished road
just FYI, i was experimenting with this as well, since all my ringtones were in .mp3 format and i didn't want to have to convert them.
by pairing my Q to my Windows XP laptop, i could right click on the Q in my "Bluetooth Devices" and choose "Send File".
i sent an mp3 over. it automatically put it in the "My Documents" folder on my Q.
then when i browsed "Sounds" on my Q to change the "New e-mail" sound, the mp3 i added was there and it works fine.
So you CAN use MP3s and apparently they will be detected if they're in your My Documents folder.
Just my $0.02.
flyboym535i is offline
