Old 06-02-2008, 03:37 PM   #1 (permalink)
camerajohn is on a distinguished road
Default What is the longest lasting battery?
I browsed the forum and I saw that Seidio makes a 3200 mAh battery. Has anyone come out with a longer lasting one?
camerajohn is offline
Old 06-02-2008, 03:38 PM   #2 (permalink)
i believe that is the biggest
Old 06-02-2008, 03:40 PM   #3 (permalink)
TreeFrog's Avatar
any bigger than the 3200 you might need a furniture dolly to move it!
TreeFrog is offline
Old 06-02-2008, 03:43 PM   #4 (permalink)
that is a very good point...
might as well just strap a car battery to your back
Old 06-02-2008, 04:02 PM   #5 (permalink)
PacoJr67's Avatar
on that point, I have a black & decker emergency jumpstarter that I use to charge my phone from time to time. so I guess I have a 700 amp battery...
PacoJr67 is offline
Old 06-02-2008, 04:07 PM   #6 (permalink)
hahah and there you have it
Old 06-02-2008, 04:10 PM   #7 (permalink)
PacoJr67's Avatar
max talk time 173 days...
*might want to pick up the simply everything plan for that*
PacoJr67 is offline
Old 06-02-2008, 07:33 PM   #8 (permalink)
Thanks... also does anyone make the 3200 mAh battery besides Seidio?
Old 06-02-2008, 07:53 PM   #9 (permalink)
TreeFrog's Avatar
I believe seidio is the only one....
TreeFrog is offline
The Following User Says Thank You to TreeFrog For This Useful Post:
camerajohn (06-02-2008)
Old 06-05-2008, 01:02 AM   #10 (permalink)
trickshot11 is on a distinguished road
i didnt see it on their website...where can you buy it?
and will the extended battery door still fit on?
trickshot11 is offline
