Originally Posted by jviren Thanks but how do I choose it? I'm trying: start>pictures and video>menu (folders)>storage card but I'm not sure that is right. Also, if I put music on the card, do I access them through the media center? Thanks so much. |
Your steps are correct. Also, yes, if you put music on the card, you access it from media center. All my mp3s are on the card. Make sure when you sync the music, your tags are correct and you sync to card. I use the usb cable and windows media player (on pc). I click the sync tab/choose music to sync/sync to vcard.
Others use "drag and drop" or copy and paste (which I use occasionally). When you open wmp on phone, you will need to update the library (make sure to open card library, not device).
You sound like you know what you're soing, so have fun!
