Old 05-22-2007, 10:54 AM   #41 (permalink)
flyme is on a distinguished road
Originally Posted by dhcalva View Post
Yeah. I just got mine and it has the gap as well. The door sits flush though without the battery there.
Does anyone have one that sits flush with the battery installed?
flyme is offline
Old 05-22-2007, 10:57 AM   #42 (permalink)
dhcalva is on a distinguished road
I am noticing that the gap on mine is getting smaller. Maybe the plastic is bending a bit in use and it will eventually be flush...
Still, i wish it was flush now.
dhcalva is offline
Old 05-28-2007, 03:35 PM   #43 (permalink)
nags's Avatar
nags is on a distinguished road
Send a message via AIM to nags
I got my battery and it works awesome. I can go forever without a charge. The one thing I've noticed though is that sometimes I'll charge my phone the entire night and when I unplug it in the morning I only show 2 bars. If I take the battery out and put it back in it'll show 3 and last just like it should.
Anyone know what would cause that?
http://www.the-nags.com
nags is offline
Old 05-28-2007, 04:02 PM   #44 (permalink)
nags's Avatar
Now I just pulled the battery as usual and put it back in and instead of reporting a full battery like usual it's showing 1 bar......
nags is offline
Old 05-28-2007, 11:25 PM   #45 (permalink)
nags's Avatar
bump?
nags is offline
Old 05-28-2007, 11:28 PM   #46 (permalink)
extremum is on a distinguished road
Send a message via AIM to extremum
I don't meant to talk down on the battery - I like the thought of having a super-duper 3200Mah battery, but that kills the phone concept of having a slim smartphone. From the looks of the new battery cover, it makes the phone look like a portable rear-projection TV. Any chance a battery like this will come in slimmer form?
extremum is offline
Old 05-28-2007, 11:30 PM   #47 (permalink)
nags's Avatar
The battery is thick and I had my concerns as well. However, the phone fits in your hand a million times better with it and after only a few days of having it on there I dont think I could go back to the stock battery.
nags is offline
Old 05-28-2007, 11:37 PM   #48 (permalink)
My dilemma is, I have a standard-fit protective case for the Q, and it will BY NO MEANS stretch that far, like trying to get a horse in a pair of human Speedos.
IF there's a higher-capacity battery available to fit the OEM cover, I'll all over it.
extremum is offline
Old 05-29-2007, 12:41 AM   #49 (permalink)
nags's Avatar
I guess I'll just give Seidio a call tommorow.. Just wanted to make sure it wasn't a problem with my phone
nags is offline
Old 05-29-2007, 08:22 AM   #50 (permalink)
nags's Avatar
Now it's jus flat out not taking a charge
nags is offline
