Old 04-22-2007, 11:58 AM   #21 (permalink)
seidioseidio's Avatar
seidioseidio is on a distinguished road
Originally Posted by uscoastiee View Post
Anyone found a rubberized case for the 3200mah?
Seidio is working on the rubberized cases for Seidio 2100 mah battery (can also be used with OEM 1600 extended battery) and Seidio 3200 mah super exyended battery. The two rubberized case will work with all three Qs (Silver, Black and Grey)
Seidio just released a new super slim rubberized hard case that can work with Silver, black and Sprint grey Q with slim OEM battery
Both of the extedned battery rubberized cases should be ready in May.
seidioseidio is offline
Old 04-22-2007, 01:54 PM   #22 (permalink)
uscoastiee is on a distinguished road
Sweet Thanks, just placed my order fro the 3200. I'll let everyone know how I think it works out.
uscoastiee is offline
Old 04-23-2007, 03:14 PM   #23 (permalink)
Aegis is on a distinguished road
I have the 3200 battery on order also. Should be here any day.
Aegis is offline
Old 04-23-2007, 10:17 PM   #24 (permalink)
Butwait's Avatar
Butwait is on a distinguished road
Smile
The seidio 2100mh battery just arrived and on the charger, 1st impression with the black cover, great not only does it balance the Q, eliminates the Verizon label and the quality of the cover is great. Now if the the power stays up I will be really happy. The purchase was painless and delivery was on time can't ask for more than that!
Black Q,Verizon,Sena case,Sprite Backup,Xtream Agenda,Qcaps,Qtask,Gentimer,Google Maps/TomTom GPS, 1G Storage card, Seidio 2100mh battery.
Butwait is offline
Old 04-24-2007, 09:30 AM   #25 (permalink)
I now have a battery error message...Q does not show battery level and on the charger I now get a red x. Anyone know how to fix this?
Aegis is offline
Old 04-24-2007, 09:49 AM   #26 (permalink)
Try to reset Q to see if helps
Old 04-24-2007, 10:14 AM   #27 (permalink)
I took the battery out for a couple of minutes and it re-set the meter. The 3200 battery is huge,, I have the aluminum case that holds the extened battery 1650 mah. The 3200 wont fit this case.
Aegis is offline
Old 05-03-2007, 01:04 AM   #28 (permalink)
Default 3200 review
Well it has been about a week or so since I started using the 3200. It doubles the thickness of the Q, compared to the stock battery installed. I use my Q A LOT. Sling my Tivo, manage my small Ebay company, check and send about 25 emails a day, use Google Maps to check traffic and so one. The 3200 gets me thru an entire day before neding a charge. I run the Candlelight app to reduce the back light brightness. It has taken a while to get use to where to put me fingers while typing and playing PocketNester. I would still like to find a case to keep my Q in. I have been keeping my Q in my pocket and have only notice the increse in weight, it really doesn't make the Q that much bigger. If anything, the huge backdoor helps me to grip the Q better while typing this post.
If anyone comes across some storage case ideads please post.
All in all, I'm happy with the large growth on the back of my Q, as it give me a crap load more power then I expected.
If you want a ton of battery time buy this battery.
Old 05-04-2007, 02:11 PM   #29 (permalink)
dhcalva is on a distinguished road
Has anyone seen a cradle that will accomodate one of these on a Q? I'd like to have a nice dock to put my Q down into for charging/syncing/ect
dhcalva is offline
Old 05-05-2007, 02:47 PM   #30 (permalink)
Galls is on a distinguished road
Do the Seido batteries have the same contact points as the standard Q battery?
I am thinking about getting the same size, but more capacity battery and need to know if it will work with this.
http://store.everythingq.com/content...5-83--1092.htm
Galls is offline
