Old 04-20-2007, 01:53 PM   #1 (permalink)
seidioseidio's Avatar
seidioseidio is on a distinguished road
Default SEIDIO'S SUPER SLIM CRYSTAL HARD CASE for MOTO Q!!
NEW version with improved fit designed to work seamlessly with Verizon Black & Sprint Grey Motorolla Q devices.
Adding to the long list of newly-developed Motorola Q accessories is the NEW Super Slim Crystal Case.
Only 1mm thick, this case offers protection against scratches yet will not add an extra amount of weight or bulkiness to your Q. To make this case as slim as possible, there is no SD card holder or belt clip.
This case was specifically designed to perfectly fit the contours and shape of the black & grey Motorola Q devices. This case has cut-outs for the keyboard, screen, memory slot, power/data port, audio port, thumb wheel, infrared port, camera lens, and flash.
This case provides a maximum amount of protection and security to your device. Once the crystal case is on your Q, it will not come apart easily and will remain safe and secure.
This case is completely transparent, allowing you to showcase your phone without any added colors or tints. The smooth surface material of this case allows for easy insertion and removal from your pocket or purse. The material that this case is made of is durable, flexible, and very hard to break or crack!
*For more information on this product, click HERE.
*CONTACT: LenaBanigan@seidio.com
seidioseidio is offline
Old 04-24-2007, 09:57 PM   #2 (permalink)
Pegleg is on a distinguished road
Do you guys plan to make this in smoke? I use my Q at meetings and I think that the smoke tint looks a bit more professional, especially when I'm meeting with clients.....
Pegleg is offline
Old 04-24-2007, 10:20 PM   #3 (permalink)
which Q do you have ? Silver, black or sprint grey ?
Old 04-25-2007, 09:24 AM   #4 (permalink)
I know that you have the smoke/pink crystal for the silver q.
I have the Sprint grey q.
In my profession (legal), things can be a bit conservative . . . otherwise I'd get the clear one.
Just my personal opinion of the week.
Thanks.
Pegleg is offline
Old 04-25-2007, 09:30 AM   #5 (permalink)
I know that you have the grey crystal for the silver q.
Thanks.
We do not have the smoke crystal case for Sprint Q yet. however, you can conside our black rubberized case for Sprint Q
http://www.seidioonline.com/index.as...ROD&ProdID=466
Old 04-25-2007, 09:39 AM   #6 (permalink)
Thanks for your quick reply.
Pegleg is offline
