Very mini...
Not sure if my experience will be yours, but I just got mine and early on I'm quite disappointed.
- Very scratchy when you plug it in, and you may have to fiddle with it to get a good connection, which will cause more incredible scratchy sounds in your ears the whole time
- Unbelievable feedback if you try to use it with your car speakers via cassette adapter (had a cable that I used with my LG Chocolate this way and worked beautifully well) This may be the phone's fault and not the adapter
- Why it's so short and doesn't have a lapel clip I couldn't say, it sure needs it.
- Seems very flimsy, the cable is extremely thin.
- Causes echo in voice calls
Sound quality seems ok. Not sure if the echo and feedback are issues with the phone or the adapter.
Bob
